configure ospfv3 area delete range
configure ospfv3 area area_identifier delete range ipv6netmask [inter-prefix | nssa]
Description
Removes a range of IPv6 addresses in an OSPFv3 area to be aggregated.
Syntax Description
area_identifier Specifies an OSPFv3 area, a four-byte, dotted decimal number.
ipv6netmask Specifies an IPv6 address / prefix length.
inter-prefix Inter-Area-Prefix LSAs.
nssa NSSA LSAs.
Default
No OSPFv3 inter-area-prefix LSAs are configured.
Usage Guidelines
If you attempt to delete a range that was not configured, you receive an error message.
The following command is used to delete a summary network from area 0.0.0.1:
configure ospfv3 area 0.0.0.1 delete range 2aaa:456:3ffe::/64
The inter-prefix and nssa keywords were added in ExtremeXOS 21.1.
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
